May 2015
  1. i would like to buy a 3d scanner what the best with reasonable price ?
    May '15
    May '15
  • 19
  • 1.5k
  • 11
Hey @Ray_Smith, I guess it depends on what you plan to scan with it. Anywhoo, the best person to ask here would be @bartv. Best of luck in finding the right printer for you!
I use a Sense scanner, quite cheap with good results. have done quite a few people with it and as long as you take your time with the scan it works nicely, the software also has some great finishing techniques as well.
hope that helps
Jeremy
I bought a Sense, it is junk for the money. The resolution is terrible, the software is weak.
You can have one for less than $50. Go on eBay, buy a Xbox360 Kinect, I have seen them for under $20. Get the software ReconstructMe (Freeware) and you have a Sense. If you have a printer already you can make your own mount to make it hand held.
Here is a bust I did with the Sense. Ok for large objects, terrible for anything under 6 inches cubed. Would never have spent $400 on it if I had known about the 360 Kinect option, exact same thing just in a different case.
any reccomend where should i check the 3d scanner ? because no one sell it on my place
Hey @print_lab! What will you be using it for? Different scanners all have different strengths and weaknesses.
Here are some examples of Structure scans:
The resolution isn’t very high, but for full-bust scans it’s okay (click on the cube icon and enable wireframe mode to see the geometry resolution better). Fuel3D has a somewhat higher resolution but will only capture a face from one side - it can’t do full head reconstructions.
There is no affordable 3D scanner I can recommend.
Currently, workable 3D scanners are all expensive.
Cheaper 3D scanner will finally be kept in a storage room, so don’t buy it if you don’t want to waste your money.
