If printed upside down you will get the poor surface on the outside (FDM specific point), If you can get it printed the right way up, the overhang is hidden to some extent inside the bulb. Depends again where the finish is critical, that’s why Hubs will often ask so many awkward questions about your product
Skip to main content
Ahh that’s why. Do you think a dissolvable support would be an option?
The part you have showed doesn’t look bad (the holes look pretty good at least)
Hi Sean
I just had a look at that file on my objet and the way I would go around this one would be to print 2 halves which would come together afterwards.
If the pice is based on a total height of 180mm tall you are looking at a fairly expensive print due to the nature of the shape. It would need a lot of structural material. Saying that though I’m quite confident that I could make this print look pretty tidy.
If you have a peak at my hub’s images, I have printed fairly delicate shapes successfully before.
Let me know if you want any further advise.
Happy to help.
Ruben
