I have had this file printed before but there were a few errors due to retraction settings etc. Would anyone be able to recommend the best way to get it printed? Or be able to print it for me? I have used a hub before for printing but it didn’t yield ideal results. Therefore I am asking what you would recommend.
Hi Sean, seams like it would be best to print it in SLA Plastic or Plaster Powder printers like our’s, Try our hub in NY and we will be happy to help you.
On FDM I think the main issue would be support on the inside of the “bulb” near the top where it starts to become near horizontal. I think that you’d need to add a column up the middle and possibly branch out with some custom support. That is FDM.
All of those tiny holes might be another challenge, but I’d need to test a small section and see. It will certainly take a lot longer I think. What is the wall thickness of the main structure?
Also what particular challenges did you have last time with the other hub?
It’s useful to know which areas are critical in terms of finish. There is another obvious overhang but I assume that will be largely hidden when fitted in place.
Doing this on an SLS printer is probably going to get you the best results, but at a cost. What sort of delivery time do you have in mind?
Good to ask… Before my hub was running, I got an stl printed for me (not via a hub) and I paid £40 for a rubbish print!!!
Wow, it’s nice. What scale do you want it? As mentioned below, the holes might be a bit of an issue, but it depends on the scale… With FFF, It might take a bit of time to make sure all the holes are clear afterwards.
Is it a light fitting? At 100%, that makes it 17.8cm tall? If you want, I’ll print the first 5cm or so tonight to see how the holes come out. (FFF).
Yeah I have thought about using the Form 1+ printer, however I need it to be this size for both aesthetic values and for the size of the bulb I am using.
If printed upside down you will get the poor surface on the outside (FDM specific point), If you can get it printed the right way up, the overhang is hidden to some extent inside the bulb. Depends again where the finish is critical, that’s why Hubs will often ask so many awkward questions about your product
I just had a look at that file on my objet and the way I would go around this one would be to print 2 halves which would come together afterwards.
If the pice is based on a total height of 180mm tall you are looking at a fairly expensive print due to the nature of the shape. It would need a lot of structural material. Saying that though I’m quite confident that I could make this print look pretty tidy.
If you have a peak at my hub’s images, I have printed fairly delicate shapes successfully before.
