May 2015
Good to ask… Before my hub was running, I got an stl printed for me (not via a hub) and I paid £40 for a rubbish print!!!
Wow, it’s nice. What scale do you want it? As mentioned below, the holes might be a bit of an issue, but it depends on the scale… With FFF, It might take a bit of time to make sure all the holes are clear afterwards.
Is it a light fitting? At 100%, that makes it 17.8cm tall? If you want, I’ll print the first 5cm or so tonight to see how the holes come out. (FFF).
Regards
Cris.
Yeah I have thought about using the Form 1+ printer, however I need it to be this size for both aesthetic values and for the size of the bulb I am using.
Cheers
Actually better to print upside down to minimise supports… I’ll print a bit and post a picture…
If printed upside down you will get the poor surface on the outside (FDM specific point), If you can get it printed the right way up, the overhang is hidden to some extent inside the bulb. Depends again where the finish is critical, that’s why Hubs will often ask so many awkward questions about your product :slight_smile:
Ahh that’s why. Do you think a dissolvable support would be an option?
Hi Sean
I just had a look at that file on my objet and the way I would go around this one would be to print 2 halves which would come together afterwards.
If the pice is based on a total height of 180mm tall you are looking at a fairly expensive print due to the nature of the shape. It would need a lot of structural material. Saying that though I’m quite confident that I could make this print look pretty tidy.
If you have a peak at my hub’s images, I have printed fairly delicate shapes successfully before.
Let me know if you want any further advise.
Happy to help.
Ruben
ruben@scalesandmodels.co.uk
Yes, I think it may well be an option. I can’t do that myself though so can’t comment further. I was thinking more along the like of suppport that could be broken off and would look like a tree -possible in 2 halfs but it would probably take quite a lot of thought and maybe some experimentation to create that support in a way that it both works and can be removed and extracted afterwards. An interesting challenge
The holes were alright, a bit stringy but that is probably to be expected.
It however failed at that height. Hence the questioning :slight_smile:
Hey man, thanks for giving this a go. The ideas are great about Lithoplanes, however I have finalised this version of the design as it has now been handed in at university.
How would you suggest to separate the parts to “snap” them together.
Thanks again
