Aug 2015
We’ve all experienced it at some point. Your prints just randomly stopping, your extruder getting clogged mid way, or anything else, the result is the same: when you come back to your printer all you see is half a print.
This happened to me this morning so I decided to make a quick post on how to make the best of the situation.
Step one
  • Measure the height your print managed to achieve.
The height measured was 44.2mm, in this case I am using a layer height of .32mm with a first layer height of also .32mm.
  • Subtract the first layer height from the total height, then divide the answer by your normal layer height
(44.2 - 0.32)/0.32=137.125
Of course, this value needs to be a whole number, and is a result of the tolerance of our measurement. this is why we did this calculation!
  • round the answer down to the nearest number
in this case 137. (This is (+1) is the number of layers)
  • multiply that by the layer height, add the first layer height
(137*0.32)+0.32=44.16. This is the height achieved, as far as the Gcode is concerned.
Step two
Edit your Gcode. In this case, I am using RepetierHost, but you may use any program to edit your code.
  • Search for the line of code indicating the Z-value. Add a Z before the calculated height
In my case, I need to search for Z44.16
  • click to select the end of the previous line of code
  • Then scroll up and, while pressing shift, click on the end of your start Gcode (all the descriptive code)
  • Delete the selection. You are now left with what you need to continue printing. Save it.
Step three
Start your printer with the saved Gcode file. Finish your print.
I tend to only use this for things I print for myself, nothing for clients, as there is usually a noticeable seam where the print failed. Anyway, I hope this will be of help as I keep seeing failed prints.
Happy printing!
    Aug '15
    Sep '18
  • 15
  • 31.0k
  • 15
Nice trick and good explanation. I’m printing the same files at this moment, the ‘Poppy’ robot.
8 days later
8 months later
1 year later
3 months later
You can use this box, it automatic cut the gcode file and go back to you Z position and print.
9 months later
I use to cut and restart unfinished cnc jobs a lot when working as a machinist. the only difference here is having to know how to get the layer height it left off on.
i tried this and i had a problem with one dimension being off about 1mm. i only had 5 layers left…
so results may vary. its also good to know my printers repeatability on the Y axis sucks.
I’ll have to get better switches for the endstops.
