Feb 2015
I try to get the license to print Fairphone cases. Therefor I need to print a case.
But how to print them? Is it better to print them vertical? But then I would need a lot of support material right?
Greetings
Franz
    Feb '15
    Feb '15
  • 11
  • 1.3k
  • 5
yes print it vertical - no support needed. You should have received an .ini file for Cura with th ecorrect settings. Even if you use a different printer the settings are a good point to start.
good luck,
Joerg
Indeed, print it straight up, I had to print one for a customer and was confused about it too, but it worked pretty well.
The only downside to vertically printing them is the fact that the layer orientation doesn’t help stability. Tell your customer to remove / apply the case with care.
indeed vertical. As a final tip I would rotate 45 degrees on the printing bed plane so you have a 45 degrees angle relative to your fans. This will make sure the fan blows nicely past the edges, dramatically improving the results on my Ultimaker 2
