May 2017
I do not see any option in Cura to use USB to print and my options on my maker select machine do not show a USB print. Where do I find the option?
The cura they have for the maker select is terrible. Go online and download a different form of cura. I downloaded the Luzbot form because it is pretty good, then just copy your settings over and their should be a control button instead of an SD save button. You might have to mess around with COM ports to get the right one. Hope this helps.
-Nick
I found a fix if you do not want to switch Cura, If you go to file >> Machine Settings and then serial port to COMX, it will pop up with via USB instead of SD, I still suggest a new form of cura because that one is not very optimized or worked on.
