Aug 2016
I have the standard CTC Bizer dual and am wish to flash the latest sailfish firmware but need to do the following
6.3.1 Step 1: Before you install Sailfish
Before installing Sailfish, power on your printer, connect it to your computer via USB, and then run MakerWare. Using MakerWare, write down the following machine onboard parameters:
1.The X, Y, and Z home offsets. These are also referred to as “home positions”.2.If your printer has two extruders, write down the X and Y toolhead offsets." HOW do I find these settings?? I am using the latest BETA makerware (3.9.2x) Thank you regardsEllen424
    Aug '16
    Aug '16
  • 1
    reply
  • 810
  • 1
    user
I have found this in makerware - Axis home positions mm - x:152, y:72, z:0, a:0 b:0
Also - Toolhead offset settings um - [0]:34000um, [1]:0um, [2]:0um
Are these what sailfish is referring to?
30
