hi I wanna rewire bed wires on monoprice mini v2, and let’s the wires goes out, under the hot bed and back in to the case. like this
But I am wondering, how hot does the bed gets below, do I need to protect the wires, from the heat, what should I use, cable sleeve, or cable tubing and what kind?
No, no special protection is needed for the wires, though you may want to wrap the wires where they might rub against the side.
You should check out the Monoprice Mini user group on Facebook. There’s tons of help and suggestions there.
Ok thanks for the help, andrew, your are very helpful
