So I have a Wanhao i3 plus. I am facing a problem where the first two inches or so of a print are not drawn. Here’s a print of a hexagon that helps show what I’m reffering to https://imgur.com/mL15yvq To create the Gcode I Use the wanhao-cura software that came with the machine and transfere via SD card. I’ve attached startofprintcode.gcode
(As .txt documents are not accepted) Which shows the first few lines of gcode produced by wanhao-cura.
Sadly I’m not sure exactly what I’ve got wrong. It’s possible I changed some settings in cura that could have caused it. Does anyone have experience with this problem or an idea as to how I could solve it,
thanks.
startofprintcode.gcode (1.27 KB)
