Aug 2015
I had this same problem with my rep 2, turned out to be what most people have commented on. Many small steps and movement, this causes the filament to be pushed and pulled back very quickly and the filament drive gear eats away at the filament so it can not move the filament anymore. I ended up replacing the thermal tape around the extruder to prevent heat from going into the feed tube and making the filament soft near the drive wheel and then turning down the extruder temperature by about 5 to 10 degrees depending on the filament that I was using. Hope this helps.
If it does not click then I doubt it’s a jam.
do you calibrate for density?
is your ext spring loaded? is your drive gear tight? does your spool drag?
I’ll post the results of my testing soon so hopefully we can solve a few more problems.
Cheers
Andrew
Thanks everyone for the responses, I am going to go through and look at everyone’s advice and then run a few experiments. Then I will post the results so that everyone can see what (hopefully) worked.
Cheers
Andrew
I had a similar issue on our reprap, the solution was to slightly increase the printing temperature or slow down your print speed to allow filament time to melt, aswell as increasing retraction length to 5 mm giving the hobbed bolt a little extra filament to work with reducing the amount of chew happening to a particular spot in the filament.
hope this helps!
Nathan @ Protoprynt
SOLVED!
