Aug 2015
Hi Lembach3D,
Hmm I think I may get more warping of the part if I print without the enclosure (plus I like to keep the fumes away from me) but I’ll give it a go and let you know my results.
Cheers
Andrew
Hi Daniel,
What do you mean by upgrade the arms and default maker it assembly? I’m pretty sure the tips are screwed in all the way, I am running one default tip and one upgraded to compare them and they seem to be the same so far.
Cheers
Andrew
Hi Chris,
That’s a good idea, I was thinking of doing almost the exact same thing, nice video btw. I’ll let you know my results.
Cheers
Andrew
Hi Chanman,
Ok thanks for the advice, you don’t happen to have a picture of what you did do you? I don’t quite understand where the thermal tape is around the extruder.
Cheers
Andrew
I’ll post the results of my testing soon so hopefully we can solve a few more problems.
Cheers
Andrew
Thanks everyone for the responses, I am going to go through and look at everyone’s advice and then run a few experiments. Then I will post the results so that everyone can see what (hopefully) worked.
Cheers
Andrew
I had a similar issue on our reprap, the solution was to slightly increase the printing temperature or slow down your print speed to allow filament time to melt, aswell as increasing retraction length to 5 mm giving the hobbed bolt a little extra filament to work with reducing the amount of chew happening to a particular spot in the filament.
hope this helps!
Nathan @ Protoprynt
SOLVED!
Hi Drydock,
Was every single of your prints failing before you replaced the thermocouples and tightened the wires? I was getting sporadic failures only, could you let me know if you have any failures after you have printed a few more objects? (just to confirm this fixed it)
Cheers
Andrew
Andrew, here is a link to show how to replace the thermal tape, in the file there is a view of the print head from underneath, the nozzle is surrounded by kapton tape, this is the thermal tape. You can purchase this from Amazon etc.
I have the same problem, I suspect a temperature problem so I am awaiting Thermistors (Thermocouples as CTC/Wanhao calls them) to be delivered. In the Makerbot program it stops with just a generic “Print Failure” window and with RepG it just stops printing with no change in the program. Any help would sure be appriciated!
-Bill-
UPDATE: Problem Solved. see elsewhere in this discussion.
Actually the thermocouples and fan wires were 2 different problems (lucky me!). The faulty fan wires would allow a 10-15min print job but the thermocouples would throw a temp failure. Both thermocouples went out withen a week of each other and I would continue to print because when 1 went out I set the machine as a single extruder (Tool Count = 1) in the sailfish firmware. Trace your fan wires to the plug on the MB and move them around trying to get the fans to stop. If you can get them to stop, you have a problem. I am, of course refering to the MotherBoard fan and NOT the extruder fans (of which I thermal epoxied alum heatsinks w/fan on the back of the extruder stepper motors).
eBay item number:
351047246939
-Bill-
UPDATE
Ok so I stopped directing the lamp into the enclosure and I also took an old bedsheet off the top of the enclosure (which I was using to keep the heat it) and it seems (don’t wana jinx it) to have fixed it. I have run 9 prints with no stopping extruding including two 4 hour and one 13 hour print. Although now there seems to be a tiny bit less adhesion between layers but I will still keep tinkering with the settings.
Thanks to everyone for the advice and suggestions especially to @bumsarama who suggested running without the lamp.
Cheers
Andrew
EDIT
Ok so the first print I ran after this failed after about 30 mins (typical) but this was using the left nozzle (standard makerbot) and all the other prints that worked were using an upgraded nozzle on the right hand side. So I am going to try the right nozzle with the same print and see if it works
I was just having this same “notch” problem with the replicator 2x as well. Glad to see it has already been addressed. Raised the temp to 240 and am going to try it now. Excited and hopeful. Great site here!!
1 year later
Hey Andrew,
I seem to have the same problem .The extruder gear is eating off the filament coz of the continuous tiny movements. And it makes a notch and it is not able to extrude further , usually freezes off after 3 to 4 layers(usually the supports). Did changing the thermal sheet in the extruder work? Or reducing the temperature work? I tried to reduce the velocity of the print to 10mm/sec(from 90mm/sec) to reduce the viscosity. It did not quite work for me. Any suggestions on how to fix this problem ?
Hi Manush,
I found that my fans were installed the wrong way around, they were sucking rather than blowing onto the heatsinks, so I switched these around and also upped the temperature. Upping the temperature seemed to work. I still have the occasional failure but nowhere near as much. Also clean the extruder gear (where it is notching the filament), hopefully this works for you too.
Cheers
Andrew
