and its awesome i learnt so much about it. at first i used to use the cura i got with the sd card provided ver 1.5.x something and it was almost perfect. the support was amazing it supported the print perfectly and it was really piece of cake to remove but then i got recommndation not related to use the newer version of cura and i tried it out. i cant say enough how i am happy with it but there is one thing. the support is way stronger harder and more difficult to remove then the other cura i used and i finished breaking up the model. i tried to play with the support pattern and density to make it as it was on the older cura (on the older cura i found it was “lines” and on the newer version it was “zig zag” so i changed it to lines and it helped a little bit but still its so hard to remove downgraded the density from 15 to 6 and still didnt solve the problem can you please tell me how do you deal with it yourself? i cant understand how can you make it work. please tell me or is there any way to make it as it was on the older cura? there are so many settings on that newer cura it will be absurd that you cant do it as it was what do i need to change. or just tell me how to deal with it. thanks so much
created
Dec '17last reply
Dec '17- 1
reply
- 661
