Jul 2015
Technical parameters:
  • Integrated SD card with LCD monitor display.
  • The Layer Thickness: 0.05-0.4mm
  • Layer Resolution: 50 microns
  • Printing Filament: PLA & ABS. Heatbed Required for ABS.
  • Technology: Fused Deposition Molding (FDM).
  • Construction based on parallel arm (delta).
  • Machine dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight: 10 kg (including packaging)
  • Outer frame: imported aluminum, steel (laser precision cutting)
  • Extruder:remotely and high-speed extrusion machine
  • The print head material: copper, aluminum, polyether ether ketone material forming
  • Nozzle diameter: 0.4 mm (E3D-V6) Nozzle temperature:280℃(max)
  • Filament diameter: 1.75mm
  • Nozzle number: single nozzle
  • Data format: STL
  • Software: Repetier host
  • Print range: 160 mm diameter height 230 mm
  • Power input: AC110-220 - v
  • The power supply output: DC 12 v 7 a
  • Print plate: high borosilicate glass 180 mm in diameter
  • Synchronous belt wheel / 16 teeth, belt GT2
  • Upgradable to heatbed.
  • http://www.reprapmall.com/index.php?route=product/product&path=34&product\_id=46
  • sales@reprapmall.com
