Hello all,
I am struggling with printing Marvin’s ring especially when I use 0.35 mm layer height. The problem is the more high usage of layer height (up to 0.35 mm because my nozzle diameter is 0.35mm), the more I get trouble with it. On the other hand, if I use low layer height, for example,0.30mm, I print Marvin’s ring good enough but there are some deformations like rounding and crashing into it.
- printing heat 180
- printing bed 60
- flow rate 100
- feed rate 100
I also had tried,
- printing heat 175
- bed 60
- flow rate 90
- feed rate 110
the result was not bright.
Therefore, I want to find the perfect balance between these two options. Is there anything to re-consider the aspect of producing Marvin’s ring?
Thanks.
created
Apr '16last reply
Apr '16- 4
link
