I installed the E3D metal hot end on my Hatchbox Alpha. I also installed the (supposedly) screw in compatible thermister.
Using M303 E0 S200 C3 it should run a series of 3 heating cycles then give me an average of kP, kI, and kD…but the ONLY way I can get it to run multiple (3) cycles and return results is if I chance the value of C to “1”…???..
Once I enter my PID settings in the configuration file and save to EEPROM and try to heat the head it just goes…zoooooom…to max heat and then the heater is decoupled.
I did manage, at first, to get it to the correct temp after inputting my PID settings but it would rush past about 10* C then fall back and have a range of +/- 3* while holding temp. According to firmware I dropped P slightly and raised D slightly…which did tighten it up. I managed two good small prints…then cycled the power and I haven’t been able to get it to work since. (Yes, I did check and the values I entered were stored in the EEPROM).
Help!
Jay
Did you ever figure this out? Going through same trial and error process that you described here. Any guidance or hints that you may have from 9 mo ago is much appreciated!
