Aug 2015
If you like growing plants, but don’t have a garden or enough space at home, this will be a product for you. It’s a one plant greenhouse, but you can print as many as you like or reuse the one you already printed. When the plant has grown take it out with the inner flowerpot, print new one and use the rest of already printed parts.
UAU Project wanted to make GROWW as available as possible that’s why they give you parts to make it with both most common jars in the US & EU: wide mouth Mason Jar and 82mm diameter thread jar. Apart form the jar (wich is the only thing you need to supply to finish GROWW) all other parts are 3D printable.
Designed in Warsaw by UAU project.
Download STL here: STL file GROWW. the minimal greenhouse・3D printing idea to download・Cults 7
More informations about the project here: http://groww.uauproject.com 6
    Aug '15
    Aug '15
  • 9
  • 3.0k
  • 9
Great design,
I was wondering. are there any holes in the design ? Does a plant need fresh air ?
Hey @Sean_1, thanks! We wanted the design to be as simple as possible and easy to print with every printer so Groww doesn’t have any holes. Offcourse the plant needs fresh air every now and then as it also needs watering. To do both you simply have to lift the jar part for a while. Our tests show that you need to open the plant when there is too much moist inside, what you can observe when water droplets collect on the inside of the jar. As a side note i can tell you that we didn’t need to water our plant for the past 12 days :slight_smile:
