I can at least share my experience printing woodfill fine on my UM2:
- nozzle temperature at around 205c (you can play with the temp setting to get different color effects; even with a Cura plugin to make it dynamic during the print)
- normal print speed (50 mm/s); faster won’t give better results
- 0.2mm layer height (to assure enough ‘flow’ through the nozzle, else it might block/burn at some point in the nozzle)
- I used glue-stick on the glass plate to fix the print and the plate temp at 40c
- Fan speed after the first 3 or so layers to 100%
I print some small/delicate stuff and some bigger, more solid items. Woodfill is really good for print more solid/bigger objects. If you go on really fine details, then I might give a rougher finish.
I did as you said and used the normal print settings with some changes (see attachments) and it actually printed just fine. I only need to print the supports a bit further from the rest I think.
This is very interesting, since all my previous attempts were based on the profile provided by ColorFabb on their website 1. It seems that something in their profile is fundamentally wrong for my situation.
The second attempt did fail again… Damn. It was over 2 hours in, and then suddenly the extrusion stopped again. It’s still way better than before since it stopped within 30 minutes before, but still no 100% success rate yet.
I have the same problem Bjorn, and I’m still searching for the most optimal setup. Any luck since the last post here…?
P.S. since i have lots of people asking me about woodfill and other special filament so I ordered 3dsolex “Olsson Block”, new modification for UM2 (link to the UM forum: http://umforum.ultimaker.com/index.php?/topic/7689-custom-heater-block-to-fit-e3d-nozzle-on-ultimaker-2/) and since it will allow me to change nozzle easier and to even be able to print with bigger nozzle I hope it will make all the difference when printing woodfill. But untill then still frustrated with failed prints.
I actually have an update: I printed 3 (Three) wooden objects without any problems now.
The trick in the end was to set the speed even higher.
I now have:
First layer: 20mm/sec (I think you might need to raise this for larger objects when the first layer takes very long)
Layer 0.2mm
Outer shell layer: 50mm/sec
Rest: 80mm/sec
Retraction: 5.5mm @ 40mm/sec
Layer 0.15mm
Rest: 100mm/sec
For the rest of the settings I used the standard Cura Normal Print settings.
I noticed that even though I set 80 as overall printing speed and set the others to 0, that top and bottom still had variable speed. When I set the speed on 80 manually (so not on 0) it seems better and less risk of getting stuck at the final layers.
I tried the outer shell @ 80mm/sec but that gave a very ugly result.
Another trick I learned: In cura, you can add a second Ultimaker to your machines, but in stead of ultigcode you choose the Reprap / m… something. This gives you more options in the gcode, like printing temperatures, retract settings etc., so you don’t have to set them manually on the printer. I added a line to the starting gcode to make sure 30mm of material is extruded though, since in the default settings there is NO extrusion at the beginning. I’ll upload my profile later, so you can simply open it in Cura after adding and selecting the UM2 with different gcode setting.
Wow, Bjorn…this is awesome. Thank you so much for the information. I will try it out today.
Just one more question, at what temperature did you print these…?
And once again, great job.
I’ll post a small howto tonight including how to setup a second printer profile etc… Hope that it helps for a lot of people since this stuff seems almost impossible to print
I’ve been tweaking a bit after the post above I think. Did you try the profiles from bjornsblog.nl?
I do have those resin drops though. Usually after the first few layers. When I see it I pause the printer and whipe the nozzle clean. I do this very fast since this is obviously a risky operation with Woodfill.
My WoodFill prints are successful in many occasions, but still not always. It’s a beautiful material but it’s almost impossible to print 100% successful with it.
Great, thanks for sharing your experience, Bjorn! I am trying to print with ColorFabb Woodfill for a while now and can’t get it to work flawlessly. Your settings helped a bit, but still, I get these resin drops before the nozzle becomes clogged (See attached image, which shows just the support structure with one drop). Sometimes after a few millimeters of print height, sometimes significantly later (few centimeters). I tried the settings from your blogpost, from ColorFabbs blogpost and played with temperatures between 195 - 210. No success… Has anybody else experienced these resin drops?
