Did you print that wrench as one piece? I have printed a couple hinged parts on my Form 1 and the resin seems to cure in the gaps. Great looking parts!. Get some mineral oil from drug store and use that to shine it up
No! I tried to print the wrench in one peace and all the peaces got stuck. So then I got thee Idea to print it in three ways the wrench it self and the other to parts by them self and the resolution was fantastic! Thanks for the tip with the mineral oil. Cheers Sunshine prototyping’s
The clear resin is terrible for functional parts. It cracks, chips or shatters very easily. It’s hard to beat good old FDM ABS for functioning parts. The new tough resin from Formlabs is pretty good, and I’ve had nothing but success with it, however at $175 a liter, it doesn’t make sense to print larger functioning parts like wrenches and screwdrivers.
http://formlabs.com/support/guide/prepare/design-specs/
Leave 0.5mm between two moving parts and clean your parts immediately after the print finish, so the resin doesn’t cure.
It also depends on the orientation, 0.5mm will allow the clear resin to escape.
