May 2016
I have a FlexTPU spool (http://www.3dfilamenten.nl/groen-flex-tpu-filament-1kg.html 1)
and I was wondering how can I print this ? I have a Dreammaker Overlord Pro with a 1.75mm extruder. I’m quite new in the 3D printing (also with my printer) so I was hoping there are some tips ? Can I just print (at which temp.) and are there any problems that may cause defective printer ?
    May '16
    May '16
  • 1
    reply
  • 906
Your success will depend a lot on the extruder setup. If you are comfortable with maintenance on that printer (removing jams tearing down the extruder) you should just try it and see what happens. Print very slow and move up in speed not down. Also by looking at the machine specs the hotend is only rated to 250 so make sure your tpu doesn’t require a higher temp.
