Question. What does it mean when there is a red outline on my print? (Please see Screenshot) Not sure if that is some kind of warning concerning that specific print. Any insight on this would be great. Thanks!
Looks like the red is simply outlining the edges of the print.
Here’s a thought… what’s the width of those walls? Maybe it’s showing walls that are too thin or something?
Did you receive an error message that there may be errors in the model and ask you if you wanted to fix or ignore?
What version of Flashprint? Is this STL available to test?
I’m using version 3.16.2, I’ll attach the STL so you can take a look. Thank you so much!
card_tray_-_small_cards_zombicide_v1.1.stl (163 KB)
I did get an error about repairing the model which I do, Funny thing is I only get the red outline with this print. Smaller print areas come out fantastic so far, it’s the larger ones I’m having issues with.
Run it through autodesk netfab or simmilar…I had same thing and it didn’t print the surface layer on area shown in red.
I’ll try to check it out this evening.
