Hi
I’m trying to print PCL which has a printing temp of 130 deg. I have a HICTOP printer at home and it has a setting in the firmware that avoid the extruder motor to run below 175 deg. I’m currently printing with a Flashforge The Creator and I wonder if it has the same setting
As I like to risk I tried and it worked, so problem solved. If anyone may be interested PCL is printable with Flashforge The Creator dual printer.
