I notice the latest software up date does NOT have ‘Surface to platform tool’. This I used extensively.
My guider also seems to have lost the ability to do the assisted levelleing and will not goto all 3 corners only leveling one or 2? Any ideas on how to manually calibrate.
Last question, I have an stl file that loads with no errors however is missing surfaces when slicing. I have tried nettfab with no success (looks fine in there - until slicing).
Any help would be appreciated.
thanks
Brett
itech
It might be a good idea to revert back to an older version of Flashprint, if it worked before. You can still download older versions of it from Flashforge’s website.
http://www.flashforge.com/support-center/finder/
I know this says the Finder model but it’s still the same software.
Probably should plug in a do a firmware update as well, that might help with the assisted leveling issue.
I use a custom script for leveling, using the paper between the nozzle and bed trick. Create a simple text document and paste this code into it. Then rename the file to an extension of .gcode or .g :
G90
G28
G1 Z0 F600
M18 X Y
M0
G91
You’ll have to manually move the head to the three adjustment knobs and friction fit a folder piece of paper to get the proper adjustment out of it.
I know this code doesn’t fix your problem but at least it will get you leveling again.
Good luck,
Dano
try meshmixer for repairing files. it can do some stuff netfab can’t do, also free http://www.meshmixer.com/download.html
Thanks Dano, I’ll have a look.
Brett
Thanks Itech, I’ll try that. Wasn’t overly happy when it did work with result.’
Regards
Brett
