Apr 2016
Recently, my FlashForge Creator Pro has stopped working. The head will move, as if it is printing, but no filament will come out. I have talked to a few people personally, and they told me to look at the filament after trying to print. I did, and saw that there was a scrape on the side, like an indent. They said I needed to adjust the tension.
I don’t have much experience with tinkering with 3D Printers, so I came to this website for help. How would I adjust the tension? Would I need to increase or decrease it?
If anyone has experienced and fixed this problem, or knows what’s going on, your help would be much appreciated. Thanks.
    Apr '16
    Apr '16
  • 6
  • 3.5k
  • 3
Sounds like you have a filament jam. I’m not familiar with the FFC as I’m a RepRapper, but is there a way for you to release the tension and push the filament through by hand. If it doesn’t extrude you could have a jam or a plugged nozzle. Also, can you verify that your nozzle is heating up to the proper temperature. Is it hot to the touch?
Also here is a similar topic to your problem: https://www.3dhubs.com/talk/thread/flashforge-creator-pro-pla-extrusion-problem 37
I have tried all of this, and nothing works. Can someone tell me simply how to adjust the tension?
