Aug 2015
Does anyone know the starting g-code for a nozzle line wipe command for the front of the build plate? My Dreamer does the line in Simplify3D but my Creator doesn’t and it’s a little frustrating getting the blob in the corner. I would love to change it in S3D.
Thanks,
Chris
    Aug '15
    Jan '16
  • 7
  • 2.2k
  • 6
If you look in the starting G-code of simplify 3D it says purge nozzle. If you want to remove the blob on the corner just delete the whole line. Otherwise I just reduce the E value in that line to be 5 instead of 25 which is just enough to make sure the nozzle has filament in it. Hope this helps
Contact Simplify3D support and they will send you a profile with the correct startup gcode. I had an issue with this on my Creator Pro after the update to 3.0.
Thanks for the suggestions. I ended up contacting S3D support and they sent me over a profile, works like a champ now.
Hey Chris,
I am pretty sure I know what you are talking about and it is rather annoying! I’ve attached some modified starting gcode for you, so punch it in an see how it works! If we are talking about the same issue, it’ll do the trick :slight_smile: Let me know how it goes!
Nate
*EDIT* Ah, looks like I got in a bit too late on this XD Glad it is working for you though!
The Code.pdf 10 (81 KB)
5 months later
