Hi everyone
I need some help for my 3d printer creator pro. Actually the problem is related to heating bed of the printer goes beyond my set temperature i.e 100C as a result printer does not print.
please help
What kind of slicer are you using?
Do you have override g code setting on in the printers manual settings ? Email me saprototyping@gmail.com if you need some help
Did you ever solve this problem? I have the same issue, which was caused, I believe, when I shorted the two exposed solder points on the small pcb at the rear of the hpb.
