I recently managed to get a hold of a CTC 3D printer. I know it isn’t the best one but I got it second hand for £100 so I can’t complain. For my first attempt I tried to print something I found on Thingiverse however it didn’t go that well (see the attached image). Can anyone recommend how to fix this? I assume it’s the temperature however I’m not sure if it needs to go higher or lower. I’m using PLA at 190C onto a non heated bed covered in masking tape and I have leveled the bed.
Thanks for the feedback. I got myself a small usb powered fan and set the speed down to 70mm/s and it seems to be printing a load better now. It still clumps up a little bit on overhangs but not by much. Probably just a case of fine tuning the speed and temp of the print.
70mm/s is too fast, try 30mm/s. Also goto thingiverse and download some “calibration” files … see how those print and then you can retune your printer based on the results. I can send some links later if that helps too!
