i have wahabo 3D printer i3 plus,
i printed object with it using PLA and FilaFlex
now i tried to print one more using filaflex but the filment is not coming out,
although i used the same parameters,
and when i tried to remove the filment, its stuck and it gives bad sound
how can i clean the extruder !?
JSelb
Hello sara1122, I would be heating the extruder up to printing temperature, and then trying to gently pull the filament out out top. From my experience, when the filament is soft while printing, it fills the chamber in in nozzle. Then when it cools, the filament takes the shape of the inside of the extruder and so it cannot be drawn back up the extruder body. I hope this helps, it is the first thing I would try myself. There are other things to try as well.
I tried doing that , but it didn’t work, it seem like the filement is stuck am afraid if i pull harder, it will cut and small piece will remain inside
i cannot understand why the filment is not comming out from the extruder head , although i heated it to the right temperature.
Flexible filament is tough. Its like trying to push spaghetti into a hole to force the material out.
If its down in your nozzle, heat it up, and put PLA through it to push it out.
It is also common for flex filament to wind around the gear, creating a knot around your extruder gear. You might have to take the fan and heat sink off your extruder and take a look.
JSelb
The other thing you can try is to ‘flush’ the flex out; pull as much out of the top as you can, and then feed some PLA through the nozzle as well (assuming they are for the same temperature). Failing that I would cool the head down, and take the nozzle off with an open-end spanner. That way you can see what happened inside as well
A calendar is used to manage time and work activities. Download April 2019 Printable Calendar, May Calendar 2019.
