Aug 2017
I just got my monoprice select mini 3d printer, and the filament is stuck. I can’t even take out the filament! I had printed multiple prints before this, and I assume it may be a clog or a jam?
What should I do to fix this?
    Aug '17
    Apr '19
  • 6
  • 34.6k
  • 7
Are you trying to change filaments? Are you following the filament removal instructions for your printer? You have to heat the extruder and most likely run an unload filament routine on the printer. You pull on the filament as it unloads.
2 years later
I had this EXACT same problem. No amount of pulling helped and heating it up didn’t cut it. What you need to do is heat your printer well above the normal printing temp and remove the fan (2 metal springs hold it on and are relatively easy to remove) leave it just hanging there and don’t loose the clips. Let your printer sit at that temp for 5 to 15 minutes. It should be able to pull loose at that point. Than vigorously feed filament through your machine to clean out the nozzle. Attach your fan and resume printing. (Worked for me at least).
