Filament is the life blood of 3D printing. We have said it before, and we will say it again. However what good is any filament if your printer manufacturer only allows use of their filament? This would limit your printers capabilities drastically, hindering the true potential of what these jaw dropping machines can do. The sad truth is that many companies are this. They are only allowing you to use pre-loaded filament cartridges that come from that specific supplier. Now not only do you have to buy only from that suppler, you can only get the materials that they have available. Most of these companies that lock down filament will say it is so that the quality can be controlled for great printing, this could be true, but the filament we make at Filabot has the same if not better tolerances compared to this commercially purchased filament.
Here is a list of printer companies that are limiting filament, and the potential of 3D printing:
Makerbot - Sad but true, the printers can only use the spools that makerbot has
XYZ - Low cost printer, high cost filament. Can only use XYZ filament
3D Systems - High cost, limited material types. Can only use their filament
Here is a list of printer that allow for any type of filament to be used:
Printrbot - Great printers, great prices, great prints, open filament usage
SeemeCNC - Delta Style Movement, open filament usage
Luzbot - Open filament usage
Ultimaker - Open filament usage
Hi Toby, we have settings for the Makerbot here: http://shop.madesolid.com/pages/printer-settings We also believe that printers should be made to use any material that a user wants to use and that’s fundamentally why we are in business. If you haven’t used MadeSolid’s resins or filaments yet, then you’re missing out!
Nice, this is truly awesome guys! Care to share some images of the printing results? Cheers
