I have been using my Creator pro for a little while without issue. However recently after a failed print I began having problems. Initially it seemed to just go off to the left midway through a print. I changed the x axis cable as apparently this was a common issue. However now whenever I start a new print it begins on left edge of build plate and then ends up banging against side if I allow it to try to print. Everything seems to work when I use the jog, I tried adjusting the home offsets thinking this might be it. This just changed where the extruder would sit prior to printing. What I found odd is when I put the home offsets to 0,0,0 it centered on build plate. This would suggest to me that the coordinates are not messed up. Anyone with ideas I’d appreciate it as I’m new to 3d printing.
