Just bought a FF Creator Pro second-hand and started to set up last night. No problems until I go to do a benchmark print and it begins to print off the right side, completely missing the bed.
I know little about this printer (and only a bit about 3D printers in general) but I am learning a lot as I troubleshoot. Do I adjust a printer setting or a setting in the file I am trying to print? My x and y offsets are factory settings restored at this point.
I am unsure if the previous owner updated firmware to Sailfish, but I asked and am awaiting response. I am using Simplify3D.
Check the endstop, enstop cable. Is it lighting up in the right place?
Also, make sure the offset settings are for the same for replicator 1, NOT replicator 2. See the sailfish firmware manual for setting up your toolhead offsets. People often make this mistake.
What printer did you select in S3D? There is a pre-installed profile for the FFCP. What version is the firmware?
sorry for messaging on a old thread but were you able to get the printer working?
