Hi ALL,
Total newbie here with an Anet A6. The build went quite well and it all seems to be working. Except the little fan on the side of the extruder that feeds the duct is not running during printing. I know electrically its working as when I put the printer into preheat the fan is running and also during cooldown. But when I start a print it stops running. I’m using Cura 14.07 that came with the printer and in the Advanced tab at the bottom is a section labeled COOL and at the bottom of that is “Enable cooling fan” and there is a check mark there. Is there some other setting I need to do to turn that fan on during printing? I’m getting things to print and they are not too bad but I assume that cooling is important and its not working
Any help would be appreciated.
Thanks,
Gerry
