Hey, I am encountering an issue with my Anet A8.
I wanted to print something and noticed that no filament was coming out from the nozzle.
I looked up and saw that the extruder motor wasn’t working.
I tried to move it in the settings, nothing happened, so it is not a problem of Gcode or whatever.
I wanted to test if the problem was the motor or the motherboard so I changed the port on which the E motor is plugged in (I plugged it on the Y port).
Then I tried to move the E motor (By moving the Y motor in settings), and it worked
Also, I plugged the Y motor on the E motor port and this time it wasn’t working.
I concluded from these tests that my E motor port doesn’t work anymore. Do you have an idea if it is a common issue and if there is a fix or am I good to buy a new card?
Thank’s for your help ^^
