Jan 2016
Hi guys, to 3DPrintandstuff; You are correct in your initial statement taken from what I said. I looked at my slicer setting as I have selected the head i want to print from (3rd head) and set the temperatures and everything for it. But when i save this onto the SD card it heats the bed to my specified temperature but chooses the 1st head to heat to my specified temperature. I will double check it again to be totally sure but i understand why its doing this. I am only trying to print from the 3rd head and the head was to be heated to 230 degrees and the bed to 50 degrees. To answer spark111: I used slic3r to slice it but it does it in repetier. When i go to slice any model repetier asks me to pick a slicer engine and it externally opens up the package. I can pick from slic3r, skienforge and Curaengine. I have always used slic3r because i know it best, and never used the other 2. To answer 12x12InchPrint; the defualt head is the 1st head i think and i can print fine with this. It prints a different material and my goal is to eventually do a dual print so i need to fix the problematic head to do so.
