I have had an Ender 3 for about a month now and have been printing with no issues since I got it. A few days ago, I started a new print with my Ender 3. The print failed, as it looks like it stopped printing about halfway through the print, then started again after a few minutes, rinse and repeat. The entire time there was filament in the printer, so I thought maybe the filament was bad. I tried changing to a filament I had no issues with in the past, but the same thing happened. I tried tuning my settings in Cura, nothing. I tried switching to Slic3r, nothing. I tried cleaning my nozzle with the Atomic Method (Cold Pull) as described by the 3D Printing Nerd, didn’t help. Finally I gave up and posted this and this on Reddit. So far they have given me plenty of helpful advice, and I have tried a lot of it, but so far nothing has helped. I gave up with cleaning and tried replacing the nozzle, and now it seems like it extrudes normally for a minute, then it suddenly stops for a minute or two, then it starts to come out really fast. Here is what I do know:
- The printer is gripping the filament fine, as the filament has small teeth marks on it when I remove it.
- It seems to feed fine when I push it manually.
- It behaves the same with all of my filament, though I have yet to try brand new filament.
- The Bowden tube has not been pulled out of the extruder partially, as I have removed and reinserted it 3 times now.
Any help or advice would be greatly appreciated. A picture of how my prints are turning out can be found in the Reddit posts.
MaddieG
What temperature and speeds are you printing at? It’s possible the issue may be “heat creep”
The nozzle was at 215°, as the filament manufacturer said. I was printing at 60mm/sec, which I have been for a month.
Did you tighten the drive gear on the extruder motor?
Credits go to tkuan
MaddieG
have you measured the filament for actual size and consistency as well?
Did you ever fix this? I am having the same problem
Thanks!
