Sep 2016
@Mindfull has good info here. People always wonder why I tell them to print at 73mm/s!
There is a strong indication that your resonance can match stepper movements, etc. I had this exact situation on some extruded text on a print. I kept getting slower and slower on the print… First 60mm/s, then 30mm/s, then 15mm/s. All that happened was the ringing changed. It actually almost went away at 73mm/s. I have been printing at 73mm/s a lot after that (xy print speed).
Yes, and it makes some sense because I can see that it does the inner loop then hits the outer and reverses direction so there is momentum from direction change and lateral position change.
Before changing speeds I am going to try a print (just top part) with random and also with most efficient start-stop and see what I can see. Just for fun.
Interesting. I was told recently that a full step on the Z is 40 microns to make layer heights a multiple such as 1.2 instead of 1. Another thing I pick up is this for better resolution prints and save some time is drop to 1.6 layer height and print the infill at 3.2 every other layer. Seemed to work out ok.
Ok, test 1, slowed non print X-Y movement down from 4200 to 1000 and no difference.
Now running at reduced print of base 1000mm/min and 50% outer shell. Almost done.
Watching the preview while printing it is the direction change doing it I am convinced. It goes from the inside ring to the outer with a direction change at the seam and then the outer to the inner with a direction change again at the seam and I can see a similar effect on the inside in the opposite direction from the seam.
Ok, speed at 1000mm/min results are pretty good. Going to ramp up a bit and see if I can find the break point.
This thread is dealing with vertical ringing along the x/y, so I dont want you to come to the wrong conclusions when you apply that to layer height, which has a slightly different effect.
As far as infill at every other layer, this can be good if you are printing under certain circumstances, and at a small enough layer height. When your height to width ratio gets too high, printing every other layer of infill, you can get infill that does not adhere well, making your part weak, or it can become so wispy it does not hold your top layers up well.
But yeah, printing infill at every other layer, and support at every other layer, when it works, is GREAT! (really increases printer time), and I do it for my personal printing sometimes, but not for my professional printing.
