Feb 2016
I have this same issue with my flashforge dreamer, I related it back to when i attached the extruder to the machine and tightened one side more than the other, I have just been using the right as a spare holder.
I’ll second this as it is what I do as well. You’ll want to make sure the extruders are very close with adjusting the grub-screw first. Then you can make each extruder exactly the same with this method using a feeler gauge with the nozzles measured from the same bed position under the front leveling screw.
Post-it notes work well since they stay in place. Cut the strip you need with an exacto. I make a piece that is the depth of the bar front-to-back and has cutout to go around the screw. Almost a [ shape around the screw coming up from below.
Nate, dont suppose you could take a pic of what you are describing, re the position of those post-it notes?
thanks!
The image below shows where to shim, on the surface highlighted yellow between the bar mount and plastic carriage .
Unscrew the two screws that hold the extruder assembly to the carriage.
Put a shim of paper or thin plastic under the left side if you want the left extruder to go higher (if it was lower than the right).
Do this on the right side if the right extruder is slightly lower than the left.
I find that post-its are measuring about 0.003" or .09mm
3 months later
This just worked perfectly for me. Thanks! Brand new to this and couldn’t print my first piece. Now, I did it without a problem! Glad there are so many good 3D communities online. Cheers!
3 months later
https://support.makerbot.com/troubleshooting/earlier-products/replicator-original/my-dual-mk8-stepstruders-nozzles-arent-the-same-height\_11812
I haven’t tried it myself, but in looking up the answer to this question myself this is one of the methods I found more than once. Granted it feels like a “JUST USE DUCT TAPE” sort of method, it theoretically works if MakerBot themselves documented it on their website and other forums lead to it.
Alternatively you could go with this upgrade I’m considering as well - http://store.wmdproducts.com/index.php?route=product/product&path=63&product\_id=62
Hopefully 6 months haven’t passed without any answers, but even if so - here you go. Good luck! Let us know if your actions are successful and how you did it.
- Chris Dastan from the STAX3D Team
