I have a flash forge creator pro, and it seems that one extruder is slightly lower than the other. My right extruder seems to be slightly higher while the left is slightly lower, and this is resulting in the left extruder hitting the print and destroying anything I am trying to make. My left extruder still doesn’t work ( thanks to MadeSolid filament) so, how can I correct this issue
I had the same problems, what I did was to remove the fan from the higher extruder, loosen the two screws on top of the assembly and move the stepper motor aside so I could reach the little grub screw behind the extruder that fastens it.
First level your build plate with the extruder that is lower.
Then loosen the screw just a bit so you can move the extruder up and down with a little force.
Put a the sheet of paper that you use or leveling under the now loose extruder and knock (with the handle of a screwdriver or something similar) on the metal pipe on top of the extruder to push it down until the friction, when you move the paper, is the same as with the other extruder. Then tighten the screw again (I needed to press down on the pipe a bit while tightening the screw).
Now both extruders are exactly the same level on my FFCP and don’t scratch over the print of the others.
I use paper between the extruder head and one side of the carriage to level my heads. Just figure out which side is high and add a slip of paper then try again. I’ve never had to add more than 3 sheets on any of my machines.
This method is far better than adjusting the extruders and removing the motors and everything.
I haven’t tried it myself, but in looking up the answer to this question myself this is one of the methods I found more than once. Granted it feels like a “JUST USE DUCT TAPE” sort of method, it theoretically works if MakerBot themselves documented it on their website and other forums lead to it.
Hopefully 6 months haven’t passed without any answers, but even if so - here you go. Good luck! Let us know if your actions are successful and how you did it.
