Jul 2016
Hi
I am a student and our college has a OBJET 30 Scholar 3D printer. The printer has not been used since long and now when we started it shows " Verifying DMI Pool Data…
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
Please suggest some troubleshoot
    Jul '16
    Jul '16
  • 5
  • 1.7k
  • 6
sounds like a possible hard drive failure, contact your stratasys reseller for help.
We are distributor Stratasys in Ukraine.
Send me please a photo’s of problem and some photo’s of 3D pronter.
Best regards,
Michael
Maybe warranty? We had also HD problems and tech support from Stratasys solved it
Good Luck!
At the risk of being a pessimist here, unless the machine was prepared for long term storage, purging the lines and filling them with material that does not cure, the hard drive/computer issue is going to be the least of your worries.
Before you spend too much time on the computer, check to see if there are material cartridges installed, and if so, what type. If someone left the machine powered down, filled with resin, you’re looking at replacing all the lines, the pumps, and the print heads. The replacement cost on each head is about $1500US, plus labor.
Good luck
