Sep 2016
Hi. I have a wanhao i3 which I have upgraded with a glass plate on the bed and attached it with two bulldogclips. I have also printed the Diiicooler (made by pawpawpaw85). My problem is that the Diiicooler is so big that it collides with the bulldog clips, and to avoid that my build Volume will be a lot smaller. I tried attaching the bulldog clips on the side of the glass plate instead of on top, but then my glass plate will move. Have any of you had the same problem and did you find a easy solution to fix this? Im considering to use kapton tape in the corners to fix the build plate, any one tried that?
    Sep '16
    Sep '16
  • 813
  • 3
Thermal gino pads are an option, they are so smooth and soft they hold your bed down.
Use tiny sparse squares of it, and your bed will not move.
I just tape my bed on the corners with blue tape.
