I have a case designed using Sketchup and what I want to do is insert a design into the first layer. I don’t want a layer differential between the design and the case bottom, everything in one layer on the bottom. So for instance the case is rectangular, for the first layer I want it to print the perimeter of the case and in the middle the perimeter of my design, then infill within both perimeters. Is there a way to do this?
I suppose a work around would be to print the design I want first, and then the object with that layer thickness of the design removed to piece them together. But there must to be a way to do it in one print, right?
