Is it possible to get some feedback from other dental laboratories or technicians on the 3D Hub network about printing of dental models. From my own observations there seems to be a push by major stakeholders of dental scanners/software away from resin models, in other words ‘model free’ dentistry. It seems that constructing 3D dental models with dental technicians then going about there usual business is not on their agenda. There seems to be an assertive move towards keeping a ‘closed’ system with their own ‘3D Ready Labs’ to do the work, which is predominately and conventionally Cad/Cam Milling in other countries.
Personally, I think the whole industry can benefit from constructing 3D dental models, as an initial step forward. Any thoughts on that?
Dental models are actually very popular among my clients. I sell a dental specific 3d printer. The biggest issue with printing models is the costs involved. Resin is always going to be more expensive then plaster and the quality doesn’t change. You might not see the models around you because the inner oral scanning has not become popular enough yet to justify going to a digital model then proceeding with traditional methods. Personally I am a fan of not making models. Going directly to your final product especially if you are scanning direct impressions or basing it off of a CT scan is the best way to go. With comparison software you can check fitment without ever placing the model directly. Just be careful and do your research the FDA is on the hunt for lab owners that don’t follow proper procedures with that work flow. Also if you are purchasing resins or appliances make sure they are using FDA certified material if needed and that they follow the proper post processing steps. Many companies are NOT following this and are shipping potential dangerous product. Either way you go you cannot loose with a dental model, no FDA requirements. If you have any questions please feel free to ask away here and openly the dental industry needs to learn more about how great the 3d digital workflow can be. I would be happy to answer questions. If you want a dental model made up send it over to me I will make your first model free you pay for shipping.
I’m a CDT leading additive mfg. at the worlds largest dental lab. I hear many points of view on this subject, and can understand the reasoning behind some of it. But, while there are cases that are suitable for model- less fabrication, I will submit to you that there will be a need in a significant percent of restorations that will require a good model work to seat the appliance. Fortunately, intraoral scanning has really improved, and for it the models I print far out perform traditional impression and stone models. I have little doubt this will continue for quite some time into the future yet.
We use a number of different strategies for model making. But without making specific endorsements - not a nice thing to do in my position - any decent DLP SLA will give you good results. Great results are possible with care. Being able to check and control exposure and scaling are crucial to get dims correct.
Of course the big name machines are mostly capable of this. But let me encourage all to look into the small open systems. I shop heavily for research and comparison. Increasingly there are inexpensive systems that can do the job quite nicely.
I couldn’t agree more with what you are saying small open systems! This model is from a small open system and we have proven to out preformed large SLA and main stream DLP systems all day long.
I use a Titan I. I had to do away with their printing vat and replace this with a 15cm diameter borosilicate glass petri dish, which is held in by a rubber ring and a plastic bracket. I always print onto a roughened 3mm acrylic sheet which is attached to the print platform. This way there exists a perfect bond in the first layer of resin curing directly onto the acrylic base plate. This also eliminates any warpage problems. I have opted out of using computer generated base plates and die design, since this adds another hour to the printing process. I only print a thin rim of the dental arch (digitally cut dies though) directly onto the base plate. The base plate is then pinned and based in the normal traditional way.
I agree with this. Developments in the additive manufacturing industry is larger than just dentistry, cheaper non-dental printers can handle the jobs just fine. This also works for software. Although dental software is very sophisticated, non-dental software can also be used to make and print a dental model with relative ease.
The problem though is obtaining the STL file from the client, which at this stage is still highly encrypted by the various stake holders.
Nice job. Contrary to what the big brand name printers make us believe, non-dental printers can handle the job just as well. I get prints with incredible fine detail at 25 microns. Most dental intra-oral scanners I am aware of can only do 50 microns.
In my experience, as a ceramist, a model is still key to building up, say 6 front teeth. At this stage there is no way that subtractive manufacture can give the same results.
As far as your comment “FDA on the hunt for lab owners”: I am not sure if a 3D resin dental model is a toxic issue which is used for constructing a crown. Besides, the dentist can, by the click of his mouse, outsource the work to a third world country anyway.
Yes, that is correct. I have been to a couple of talks held by “Inside 3D Printing” where they touched on this specific subject. The 3D printing industry as a whole is still in a process of developing its ‘set of rules’ to protect consumers.
What I posted is at 50 microns and done in about 1.5 hours I would not waste my time printing 25 microns it takes too long. Yes it makes a nice model but it is overkill. Just for disclosure here I have a dental specific machine that it was printed on but it is an open system either way.
No. These are run on the horizontal. It not only shortens machine time but also improves accuracy. This is confirmed by scanning the part and comparing it against the original mesh.
Also, this is is my own resin, so I have pure control over any adequate printer using photopolymer. When you are serious about accuracy, the resin must be tuned to the system.
