So, just finished printing a few calibration objects. As usual, the printer did autohome at the end. A few minutes after I started smelling smoke, which is usually bad.
Upon checking the printer the panel showed extruder temp to be 308/0 which I reckon was the reason for the smoke. Could someone explain what could be causing this? The printed Gcode correctly sets bed temp and extruder temp to 0 as part of the end process.
Also, does anyone know whether deltawasp supports M81 Gcode command to turn off the ATX power?
Hi Toni,
If you think it could be a Gcode problem, try to use another slicer software.
If you make another print and the issue doesn’t disappear, it could be a broken of something in the regulation system of temperature.
Changing the extruder is the ultimate solution I suppose.
Good luck
v
