Hi, if you have the demo gcode into your sd you can set cura by file-> import profile from gcode. You can also go to wasp homepage, download page, to find ini file.
There are some threads in forums on the web about this question. Personally i don’t have the turbo type of delta 2040, but seems that is about the print of multiple objects. To avoid the collision between piece already printed and the extruder, you have to put the measure in vertical dimension of the higher piece u want to print. It’s only a try by me, good luck.
