Feb 2016
24 days later
Yes the file that you have is the wrong one if you send me your email (here is mine: daniel.hudson@miamiisd.com) I can get you the the correct one. The solution to to you horizontal movement going down is your delta radius offset is wrong. Any more questions that you have I will be glad to answer them.
1 month later
I have same problem
this is now killing is there any way to fix it with updated repeater host. the newer arduino software doesn’t even upload the firmware as it is not compatible.
please help
