Sep 2016
I have a CTC Bizer (Clone of Replicator 1 Dual Extruder), everything works fine, the printer works, the issue is with the slicer.
The given SD had ReplicatorG and MakerWare. MakerWare doesn’t work, it says that the background service is not running, if I try to restart it, it simply won’t start, so no slicing at all. I also downloaded MakerBot Desktop, which seems to be the latest version of MakerWare, it simply doesn’t slice files over a certain size. I tried to print the 10MB 3DBenchy.stl from http://www.thingiverse.com/thing:763622/#files 148 - it simply won’t slice it. I have another 16MB part and it won’t slice that too. MakerBot Desktop simply shows an empty view in the “Preview” screen, stating there are 0 layers and exports a 0B (empty) x3g file. Smaller files get sliced without issues, but top and bottom layer are underextruded, so it leaves giant holes in the prints. Also, MakerBot Desktop leaves gaps between the filling and the shell.
I also tried Cura and Slic3r post-processing gcode files with ReplicatorG or GPX in order to make x3g files out of them (as that printer doesn’t read plain gcode files), I can’t get it to work, if I print something, the build plate goes down and down, then it starts vibrating as soon as it reachs the printer ground (like if it’s trying to go even further down).
I’m attaching some pictures of the Makerbot Desktop with the 3DBenchy and empty preview, and also two photos of the CTC Bizer spool holder 56 I tried to print (which show underextrusion - so gaps of course - and gaps between shell and infill).
Is there anyone who can help?
Thank you
    Sep '16
    May '17
  • 16
  • 15.1k
  • 8
Spend the money on simplify 3d. It’s the best thing you’re going to do. Also, update to sailfish before you burn out your board. After that look online for mod for ctc and do the main ones to get much nicer prints.
I am using S3d also and even though it is for pay it was worth it to me. I can’t really comment of the other slicers since I have not used them really. RepG a bit and it was ok for what it is.
Does Simplify3D save to x3g? I already have Sailfish 7.7, and I was also wondering: is there any firmware capable of reading the standard gcode?
I hear lots of people telling to buy S3D but I use it for hobby, so spending $150 for a professional program is something I’d like to avoid, if not really necessary. Also, S3D doesn’t have a trial version, which would be really useful to test its potential before deciding to pay that amount.
I use Matter Slice (Matter Control) as my slicer. However, I agree with the other posts, if you can spend the money for simplify3d then do it. With Matter Slice you can actually connect to your printer via USB if you want or export to SD card. It allows you to export straight to x3g. When I get home later tonight, I can upload my configuration file for my printer. However, for now they have a profile for the flashforge creator pro that works just fine. My profile just has a few tweaks to work better with my printer.
To get the slicer, go to mattercontrol.com 266.
I had the same problem that you are having right now with my prints. Again, when I get home, I will see what I can do to help you out.
Yes it does. I also 3d print as a hobby aND I used makerware at first with proftweak. I learned alot then after 3 month I got s3d and it’s worth the cost even for a hobbyst. I know there is no trial, but look at YouTube videos, get familiar with it from videos and make a decision.
8 months later
Could you be persuaded to reupload the settings above? (if you still have them)
I am having similar problems and can’t seem to figure out the correct settings for my printer (also a CTC Bizer Dual Extruder).
