Just installed my Da Vinci 1.0 and demo print is ok.
Trying to print my first STL model returns me an error when I type “Print” key:
NOT SET UP YET
How can I solve this?
Thanks in advance.
Have you used the xyzware program for the 3d file ? So it makes the code for your printer
The only reference I could find to this problem is here: Anyone using windows 8.1 and stock software?:1865 - General - Da Vinci Printer Owners - Groups - Thingiverse
Right near the end of the thread the OP removed the USB drivers and went through a re-install. This may be a clue that the USB driver is an issue on your system.
looks like you havent plugged in your USB cable yet, or have not selected your printer.
Lower right hand corner of XYZWare is an icon, click it, scan for your printer, then try to print again.
Are u using the XYZ slicing program?
