Jun 2017
I’ve been printing for 6 months now and I’ve had this problem since the beginning. When I prints off of Thingiverse the prints have holes in the left side of the print. Does anyone know why this is happening and how this can be fixed.
Please post a photo and a link the object on Thingiverse. Also, what slicer are you using, and what printer do you have?
Unfortunately, the problems I’m able to see in these pictures are outside my areas of expertise.
Good luck.
Have any prints ever come out correctly? If so, then it may be the way your slicer is configured.
And they will still print correctly?
The question is: is everything you print recently coming out poorly, or is it literally specific stl files?
What slicer?
It looks like under extrusion but if it is only on one side it could be a retraction issue.
What material and temps? Speeds?
I use Cura as my slicer and the material I use is PLA. In regards to the speed the speed hasn’t been changed
And of the files that print correctly, were they sliced by you?
What I do is load the item from Cura and adjust the size to my liking and put it on a chip to my printer
