Hi
Started manufacturing High Precision 3D Printers, ALPHA 100 please see features below
if you are interested you can contact me for more info.
ALPHA 100 3D PRINTER
FEATURES:
  • SOLID ALUMINUM CONSTRUCTION
  • PRECISION LINEAR WHEELS RAIL TECHNOLOGY
  • BLUE TRANSPARENT PANELS ( 6 MM THICKNESS ) ALL AROUND
  • 8 ANTI VIBRATION SUPPORTS
  • LED LIGHTING ( WHITE LIGHT )
  • 20 TO 200 MICRON LAYER RESOLUTION
  • SD CARD FILE TRANSFER
  • PRINT TECHNOLOGY ( FFF FUSED FILAMENT FABRICATION )
  • BLUE OLED DISPLAY
  • UP TO 300 MM/SEC PRINT SPEED
  • HEATBED WITH GLASS PLATE TEMP. ( 50°C ~100°C )
  • OPTIMIZED AIRFLOW ( 2 SIDE MODEL FANS & REAR NOZZLE FAN )
  • CUSTOM FAN HOUSING COOLING ELECTRONICS BOARD 2 ( 50X50MM FANS )
  • NOZZLE TEMPERATURE ( 180°C TO 260°C )
  • NOZZLE DIAMETER : 0.4 MM
  • FRICTIONLESS FILAMENT ROLLER GUIDE FROM SPOOL TO FEEDER
  • SUPPORTED MATERIALS : PLA, ABS
  • ANTI JAM GEAR FEEDER
  • FILAMENT DIAMETER; 2.85 mm
  • Build volume ( 200 mm x 200 mm x 205 mm )
  • Compatible with Windows®, Mac® , Linux
  • SOFTWARE: CURA ( OFFICIAL ULTIMAKER SOFTWARE FREE )
  • SUPPORTED FILE TYPES: STL,OBJ
  • Power ( INPUT 100-240 V , 4A, 50-60 Hz, 221 w MAX ) ( OUTPUT 24 V DC, 9.2A )
  • AMBIENT OPERATING TEMPERATURE: 15 - 32°C
  • STORAGE TEMPERATURE: 0 - 32°C
  • MADE IN CANADA
DIMENSIONS:
  • 450 MM X 475 MM X 485 MM ( EXCLUDING BOWDEN TUBE AND SPOOL HOLDER )
  • WEIGHT : 15 KG
INCLUDED WITH 3D PRINTER:
  • 1 SD CARD
  • 1 DVD ( INCLUDED CURA SOFTWARE AND ORIGINAL FIRMWARE )
  • 1 pla spool filament ( color depends on availability )
  • 1 Power supply external
  • 1 AC cord locking
